How is the compatability with divx/xvid on this player? I understand it has the sigma chip which in other players have some issues compaired to some other chips. I have a collection of DivX/Xviid movies and just trying to do my homework before I purchase. They all have a max resolution of 720/480 and can fit on 1 Cd. Does anybody know of a ratio of how many of thier discs play to the ones that don't? Thanks for your input-
you may want to look at this player also -- thier support forum is on this site .. it uses the ESS chip
http://www.avindustries.net/index.php"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Finish your homework.. you dont want your grades to suffer. Then I would say 97% play ..virtually none are incompatible.
Thats promising, I did'nt realize it was that high. I guess you just hear of all the problem files unable to be played by most Divx players in this forum. -
Most of my movies are compressed with Divx version 3, and the other half with Xvid. Does it play DivX version 3 with stability, unlike some other players with the sigma chip. I really do not feel like converting my movies to v.5 with dr.divx, i would rather wait till a more practical machine came out if this is the case-
no XVID support is listed in the player's description. Anyone has experience with this one? sounds like another one of the 50 or more similar players - the price should be around $99 rather than $179Originally Posted by BJ_M
yes -- it plays xvid , no problemsOriginally Posted by absolutic"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
From the FAQ section re the Bravo D1, the player will play "MPEG-4 AVI files using ISO 9660 format and XviD encoded files". I don't have a clue what that means but I bet someone will tell us all about it soon.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Bravo SE Disc Publisher
By 16/9 in forum DVD & Blu-ray WritersReplies: 0Last Post: 18th May 2011, 06:40 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
