Hello ppl!
I got a problem, I have 26 .mpg (VCD Mpeg1 by TMPGEnc) video files on my PC. Each one is 23-25 minutes in length. I don't wanna waste 8 CDs when my other PC has a DVD burner. I use -R dvds by the way. Since they are all MPEG1 files, can I burn them to a DVD just like I would a CD for VCD so I can Fit More files per disc on DVD versus CD?
If you don't understand the question, I can rephrase it as this:
1. Can I burn VCD Mpeg1 files to a DVD? How?
2. If so, How many minutes of VCD MPEG1 video can fit on the average 4.7GB DVD disc?
Thank You for all your help!
-Xenogear900@yahoo.com
Results 1 to 9 of 9
Try the trial of Tmpgenc DVD author, it will accept the vcd mpegs and resample the audio from 44100khz to 48000khz and give you menus if you like.
Just shut up and listen dumbass -
You can fit on roughly 8 hours of vcd quality mpg on dvd-/+r.
Originally Posted by Xenogear900"Art is making something out of nothing and selling it." - Frank Zappa
ok, I will try the TMPGEnc DVD Author (For the Audio)...is there a tutorial on this website for what I am doing?
Also, how many minutes of VCD mpeg can fit on a 4.7gb DVD? -
Yes, if you just want to burn these MPEG-1 files as data files on DVD, then just go ahead as with ordinary files.
If you want to burn on DVD to watch them on a stand-alone DVD player later then there are two things you have to do:
a) demux MPEG files to M1V file and .MP2 file
b) change .MP2 sampling rate from 44.1Khz to 48KHz for DVD
c) author M1V and the new MP2 (audio) file using an authoring software.
As much as the total MPEG-1 size does not exceed 4.7GB. I assume you may have either standard VCD or (extended)VCD. For example, I did a lot of XVCD in the past (bit rate > 1150kbps)ktnwin - PATIENCE
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
