I would appreciate a suggested workflow to handle audio from AVI files to meg2 via TMPg 2.5 Plus. A guide I tried to follow suggests encoding AVI to M2G as an elementary video stream without audio and adding audio later during DVD authoring. Unfortunately, the guide didn't say how. How bad is the encoding option video plus audio, should this be track 1 or 2, and which audio option is best ? Pegasys support doesn't recommend it, but I have no tools to do other.
Carl D
I run my avi's thru TMPGEnc without first separating the audio all the time.... and use the MP2 option to aavoid the larger wav audio files. Audio bitrate gets set to 224 I get stereo as I capture in stereo.
then, I drop the mpg file into TMPGEnc DVD author to compile and burn.
Results are fine to my ears.. OTOH, I don't have a "home family theatre with exotic audio equipment"...Always check helpfiles/instructions before leaping... -
Originally Posted by distendad"Art is making something out of nothing and selling it." - Frank Zappa
I pesonally HATE the way audio sounds after TMPGEnc finishes my AVI to MPEG2. Although the alternative is pretty time consuming, I think the quality justifies the wait. Here's what I do (it's mostly freeware)... Hope this helps...
1) Open Windows Movie Maker 2 (or Premiere)
2) Capture via Firewire
3) Edit in WMM2. Save as Avi.
4) Convert Avi (Sony) into Avi (Canopus) using Canopus DV File Converter (b/c Virtuadub Mod doesn't recognize Sony Avi)
5) Extract audio using Virtruadub Mod. Save as Wav.
6) Convert Wav into AC3 using ffmpeggui
7) Convert Avi (Canopus) into Mpeg2 using TMPGEnc
8) Open TMPGEnc Author. Combine Mpeg2 and AC3 together. Author into vob file.
9) Burn w/ Nero
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
How to add audio(.mp3) & adjust in video(.mkv) & burn in vbo ?
By ashe09 in forum AudioReplies: 0Last Post: 16th Jul 2011, 03:06 -
3gp -> mp4/wmv audio problem
By dragonBoy in forum LinuxReplies: 1Last Post: 7th Sep 2010, 16:08 -
How Do Take The Video & Audio Off Of My Computer & Put It On A TV?
By Ghettorapboy7 in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2007, 10:25
