My DVD player when I put a vcd,dvd, or cd in it all it says "No Disc" when there are discs in it does anyone know how to fix this?
Your DVD player wasn't designed to read CD-R/W media.
You will have to experiment with different brands to find one that works.
CD-RW media often works better in these cases.
Regards.
Michael Tam
w: Morsels of Evidence -
...I dont think its CDRs; he said DVDs as well.
If you can hear the player trying to constantly read the disks, then try this.
Open the player up, locate the lazer and the guide it runs along. Turn the player on and watch them - it may be jammed. I had it once with a Sony CD player, "all" you have to do is "unjam" it "somehow". Failing that, try to determine what causes the player to recognise that there is a disk inside and see if you can find anything wrong. If it is a mechanical failure then it is "normally" easy to fix. However, if it is an electronic failure then take it to an electronics store and get it looked at.
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
Help with DL DVD burn no playability :edit fixed
By WBFAir in forum Authoring (DVD)Replies: 19Last Post: 25th Jul 2008, 03:25 -
Best 5 disk, Bunable DL DVD player to get ???? Edit: fixed
By WBFAir in forum DVD & Blu-ray PlayersReplies: 8Last Post: 23rd Jul 2008, 14:48 -
Burnt DL playback question on DVD players, Edit: fixed
By WBFAir in forum DVD & Blu-ray PlayersReplies: 6Last Post: 23rd Jul 2008, 11:02 -
Has the dvd filesize problem been fixed?
By Comrinec in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 19th May 2008, 14:37
