I am currently trying to encode a DV-PAL export from Final Cut Express to mpg1
I am getting the following terminal output
Last login: Tue Feb 24 10:17:52 on ttyp1
Welcome to Darwin!
pbpaste | sh
Talbots-Box:~ glenn$ pbpaste | sh
Encoding started on Tue Feb 24 10:19:02 EST 2004
CODECID 31 31 sowt
Input #0, mov, from '/Volumes/TalbotsStorage/Pheonix.mov':
Stream #0.0: Audio: pcm_s16be, 32000 Hz, stereo, 1024 kb/s
Stream #0.1: Video: dvvideo, 720x576, 25.00 fps, 800 kb/s
Output #0, vcd, to '/Volumes/TalbotsStorage/mpgtests/1.mpg':
Stream #0.0: Video: mpeg1video, 640x480, 25.00 fps, q=2-15, 3450 kb/s
Stream #0.1: Audio: mp3, 32000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
sh: line 1: 544 Segmentation fault /Applications/ffmpegX_0.0.9a/ffmpegX.app//Contents/Resources/ffmpeg -i /Volumes/TalbotsStorage/Pheonix.mov -y -f vcd -vcodec mpeg1video -map 0.0:0.0 -b 3450 -s 640x480 -r 25 -g 240 -me epzs -qmin 2 -qmax 15 -deinterlace -acodec mp3 -ab 128 -ar 32000 -ac 2 -map 0.1:0.1 -benchmark /Volumes/TalbotsStorage/mpgtests/1.mpg
I've done a search through the forums on the error and tried the things suggested like re-installing the binaries but it doesn't seem to help. Is there an obvious cause to this?
gwbootGuest
gwbootGuest
I've just read that the ffmpeg mpeg1 engine doesn't support audio from Quicktime, is this likely to be the problem?
It works through mpeg2enc but as the documentation says ffmpeg is faster and of higher quality I was hoping to use that as qualiy is my main objective with these mpeg1 encodes.
Is there an easy way of extracting the audio from a Quicktime DV file and then using it while encoding mpeg1 with the ffmpeg engine? Is the quality difference it worth the extra steps?
Originally Posted by gwboot
Guest
Thanks for the reply. I gave that a try but it gives the exact same error. The streams are also numbered the same no matter what the "invert mapping" checkbox is doing.
Input #0, mov, from '/Volumes/TalbotsStorage/PheonixQuicktimeDV.mov':
Stream #0.0: Audio: pcm_s16be, 44100 Hz, stereo, 1411 kb/s
Stream #0.0: Video: mpeg1video, 720x576, 25.00 fps, q=2-15, 4657 kb/s
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
sh: line 1: 1387 Segmentation fault
Any other ideas?
Originally Posted by major
Rear projection HD tv picture fault
By Stedalton in forum DVB / IPTVReplies: 0Last Post: 22nd Jun 2010, 13:16 -
Car radio fault
By didikai in forum Off topicReplies: 2Last Post: 26th Oct 2008, 17:17 -
Segmentation fault while executing dvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 17th Oct 2008, 19:33 -
No luck with ffmpegX - mencoder segmentation fault.
By jonnymorris in forum MacReplies: 4Last Post: 2nd Mar 2008, 14:07 -
fault on toshiba rd-xs24
By superray in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2007, 07:31
