between cbr 3000-4000, waht format do you prefer, SVCD( 480x576) or DVD (720x576)
I know that in the SVCD case is not a standar bitrate, but anyway.
I maketrying, and i think i can see more artefacts in action scenes in 720x576, but any other information is welcome.
thanks.
If the bitrate is the same, the smaller frame size will usually look better.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
1/2 D1. It's DVD complient (which SVCD isn't). Bitrate of 4000 is more than adequate to be artifact free (assuming the source isn't crap). I usually use CQ myself (2-pass VBR doesn't seem to be any better than CQ unless you are really tight on bitrate).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
352x480 (Half D1) using CQ of 85% from 4000 ... or VBR of 3500 avg and 5000 max, 0 min
CBR sucks unless it's really high (4000-5000 for HalfD1, 8000-9000 for FullD1)Want my help? Ask here! (not via PM!)
As I understand it, 1/2 D1 only supports 4:3 on dvd's,and not 16:9, so this may influence your decision. If it's 4:3 and you want to 1/2 D1, you will need to letterbox the vid.
Videonics MX-3000
By fireballtp in forum RestorationReplies: 3Last Post: 10th Jul 2015, 08:45 -
Need information on Toshiba SD-4000
By VOD0708 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2010, 12:16 -
Just tell me waht to buy please! LOL
By jboysvideo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2009, 20:01 -
Lg 42 lg 3000 color problems
By rambobambo in forum DVB / IPTVReplies: 3Last Post: 9th Oct 2008, 16:23 -
MPEG-2 bitrate > 4000 with DVD Xpress DX2?
By miamicanes in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2007, 09:12
