  1. Hello, does anyone know if it is possible to burn a xvid avi file direct to a cdr, so it can be watched in a dvd-player. I know how to convert to a svcd format but i like to burn directly if possible. Thanks...
  2. yes this is possible. as long as the file size is less than the capacity of the CDr.
    The electronic components of the power part adopted a lot of Rubycons.
  3. Thanks for your reply but can you tell me how i can do this?
