So I am re-authoring several DVDs into one and it seems the best way to go from VOB to dvd to use TMPG Author.
That said, I don't seem to be able to NOT have track menus. I want a MAIN menu when you put the DVD in but NO track menus and all the built in templates seem to give me track menus whether I like it or not.
I am sure I am missing something obvious...can only tell me (step by step) how to work around this?
Hank
click on the menu options button at the top and you will see that you can display or not display the different menu types (root, track etc)
BTW if you do create chapters they will be available on the DVD, just no menu. Personally I dont like a whole page just for tracks, the track button on the remote is just as easy
If you want the movies to show up the main page with no track pages or chapter pages then set in menu display settings
nly main menu
first action play:display main menu
action to take after each track has played:display main menu
Also click edit menu theme and choose a layout with the number of movies you want to display on the main menu,dont worry about the track layout cause it wont show.Choose a new track for each movie you want on the main menu when you first import your clips.
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 14:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 10:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 18:59
