I know, its easy (I've done it many times). But, when I used toast today to try and do it, it said that there was an error "there is a problem with the source material." error -18774. Does anyone know of any other way I could try to encode this? I have never had any problems with the files I get in mpg with encoding to VCD.
Assemble your crew, I'll meet you outside.
audio is probably hosed, or encoded
with a codec Toast doesn't understand.
use ffmpegx to resplit the file,
then remake the audio,
or try my steps I listed in this post:
https://www.videohelp.com/forum/viewtopic.php?t=207179
and then have toast re-try again. -
what if i dont have QT Pro? Im basically confused how I convert it to .avi. What settings do I use? and under which tab? I now am using divx doctor to convert avis to VCD, so I have that down (actually, very speed and easy program).
Assemble your crew, I'll meet you outside. -
Ok, i am using FFmpeg right now to split the mpg. I used Tools -> Choose file (the file i have) and clicked demux. Is that the right way to do it? it appears to be splitting. So, when it is done, what is the next step? I do not have Quicktime Pro.
how do i "remake" the audio? I have an .mp2 file.Assemble your crew, I'll meet you outside. -
just for kicks
vcdtoolsx
load up the making image function, slect your muxed .mpeg file
click VCD and then start
you will get a .bin/.cue which you can preview in VLC
just see if it works there
if so you can burn the .bin/.cue set with toast or MMB / FirestarterFX -
never undestood the bin/cue file. Do i drop them BOTH into the toast section of bin/cue? should i make it into an image first? Thanks
Gonna be hard to do without QT Pro. You will need it to be able toOriginally Posted by Mech
re-create the steps to re-mux the two halves of the file.
You could try ffmpegx to re-mux the two split halfs, once
you fix the audio.
You will need an audio editing app, one that will accept thehow do i "remake" the audio? I have an .mp2 file.
audio as mp2. You could use mAC3dec or Amadeus II. -
galactica hooked me up. seems to be working.
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 10:17 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
