I have just purchased a WD 160gb drive that came with a pci controller card.
I left my existing 20gb drive with Windows ME on my primary cable as my master and installed the WD on the same cable as the slave.
My secondary cable has my dvd burner as the master and a cd burner as the slave.
My question is should I have used the controller card to install my new drive on wondering if it would benifit the speed/performance of the drive.
I chose to use the Promise card that came with my WD 160 because I use W98SE (FAT32). The entire 160GB isn't recognized with FAT32 compression. Does Windows ME use FAT32 or NTFS? If NTFS then you are fine as is.
No, I'm from Iowa. I only work in outer space. -
[Does Windows ME use FAT32 or NTFS? If NTFS then you are fine as is.]
ME is FAT32 but my system does recognize the entire drive.
I only ask the question because the drive does not seem so fast contrary to the reviews I have read and was wondering if the card has something to do with it.[/quote] -
The add on card would be benifical for systems with a motherboard ide I/O not up to the capabilities of the new drive.
READ everything that came with/concerning the use of the add on card.
BE SURE to backup all your data before trying to use.
Better safe than sorry. -
Your Add-On-Card should support at least ATA133, i believe that ATA100 and down are limited to 127 Gigabytes.
I don't think WinME has the same partition size limitation that Win98SE has (60Gig), but they're both FAT32. -
I don't think it's the drive that's slow, it's probably your OS showing how flaky it is. You should really consider getting XP.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
