  1. I have a DVD which is appr. 7,4 GB, so I decided to split it instead of r-encode with CCE.
    I took DVDXCopy and selected no recompression, at the 'split' tab I choose the chapter where to split, first DVD was appr. 3,9 GB and second DVD 3,5 GB. DVDXCopy started to copy files to HD and then asked for a blanc DVD. I put a blanc DVD in my recorder and then I got an error with DVDXCopy, it said to look in the lof for more info.
    Now I found out that the first DVD which it wants to burn, is 4,6 GB, which is to big to fit! (I looked in the folder it created to see the size.)
    I also tried to choose a sooner chapter point for the split, the first possiblr in DVDXCopy, but same problem, too BIG.
    What can I do?
    greetings
  2. you might get some help over in the 321 studios forum.
    here, dvdshrink is usually reccomended.
    Always check helpfiles/instructions before leaping...
