I have noticed that many people experience the problem of having dvds burn like 30 secs then pop out saying they are done, this is my 2nd brand of dvd and its does the same thing.
If i use a dvd that doesnt say supports up to 1x,2x etc it wont work
if I use a dvd-r that doesnt even mention recording speeds it works fine. can anyone give my a clue on this mystery.
the mystery is what exactly is your question ?
:D
try a different media or turn down burning speed"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
