Hi
I wanted to know what is the best freeware for converting audio files into MP3 format without loosing quality.
What you are asking is impossible. MP3 is a lossy format, Period. If you encode at higher bitrates it will sound closer to CD quality but you will never get 100% CD quality from a lossy compression alogrythm.
However, try CDex with the lame encoder. It will produce very good results. -
I doubt if you could tell the diff between 320k mp3 and the original tho..this is the highest that most encoders seem to go to for some reason. I would have thought a 480k mode for true audiophiles would be an idea.
Oh, and use vbr mode.. you will save the space and get the quality. I use EAC 320k vbrCorned beef is now made to a higher standard than at any time in history.
Originally Posted by tsrusa2002
Found freeware AAC to mp3 converter
By jimdagys in forum AudioReplies: 14Last Post: 22nd Aug 2010, 17:18 -
Freeware conversion software - that works in Win98?
By AntiqueOSman in forum Video ConversionReplies: 16Last Post: 15th Oct 2009, 10:26 -
Making CD-R compilations: Best mp3 splicer freeware/cheapwear suggestions
By Krelmaneck in forum AudioReplies: 26Last Post: 2nd Oct 2009, 00:50 -
AVCHD to HDV batch conversion software freeware?
By jasonlava in forum Video ConversionReplies: 7Last Post: 27th May 2009, 08:35 -
Freeware conversion programs for AVI to DVD?
By 69ers in forum Video ConversionReplies: 9Last Post: 29th Sep 2007, 02:02
