Does anyone have this recorder and what do you think of it. I'm thinking of taking back my Pioneer 310 and getting the Sony.
Results 1 to 14 of 14
The prestigious European Imaging and Sound Association - EISA voted Sony RDR-GX7 the best DVD Recorder 2003/2004.
For more info on this recorder go here: https://www.videohelp.com/forum/viewtopic.php?t=181157&start=0 -
I just picked one up this weekend. I made one recording and noticed a big quality difference from the other 3 I had bought and returned.
Sansui, Cyberhome and Philips. -
The best tests are the ones done with several products from different manufacturers ( and if it's possible - at the same time). Only then it is possible to have a fair side-by-side test under the same conditions.
A lot of people will be surprised to find that printed manufactures specifications do not show the real performance and quality of their products. -
Well I guess this one is going back as well. It's true what they say about the quality though.
This recorder could be good for anyone and i'm sure many have had good luck. In my case, it doesn't like any DVD-R that I have thrown in. I've tried Taiyo Yuden, SONY, Tdk, Panasonic and prodisc. Some started recording and stopped (yes, all my connections were tight and tested and my source was not Macrovision protected). Some wouldn't even get that far. It would say dirty disc. All these discs would not eject from the tray either. I've had to unplug the cord and reconnect it. Wait for 5 minutes for the power off screen to disappear. Then press the eject button for it to come out. It's true also about the response time on some of the functions.
When I recorded to DVD+RW and DVD-RW it had no problems. The picture quality was very good. Now when I play those same discs back on the Sony it will not play. This obviously is a defective unit. I will not try another one because it is expensive and I don't want to risk this happening again. Also, Sony was rather cheap in what came in the box. Only one A/V composite cable. No component cable or S-video and no DVD media. -
I got the disc out 20 minutes after pressing the eject button. It's boxed and in the car ready for return.
Should I even try the Panasonic? -
Maybe you would like it. As you know, I have model E60 and I would recomend it, as a best buy, to everyone.
The only problem is the DVD-Ram. I don't support it and I'm not so sure if I want to buy another drive.Originally Posted by zorankarapancev
Yep. Actually, at this point I'm starting to think that it's not all that bad capturing to the PC, encoding, author & burn.Originally Posted by zorankarapancev
But unless you have bleeding edge hardware it's tooo s-l-o-w! I went that route for 5 years. No more. My next comp will have no cap devices in it methinks. Enough already...
PS My Panny E80 is great. My productivity has gone up by a factor of 10 when making DVDs. The DVD-RAM format is just fine with me. The LG 4040b burner bought at Christmas handles the RAM discs perfectly and I've come to rely on that format. I'm looking at other recorders for a possible spring purchase. In that case, it will be the one that suits me most, not any particular brand. If the Sony's are still going to have great hardware but picky drives, then they won't be on the list. The GRX10 sounds like a fine machine though so long as it's price isn't prohibitive... -
Not if you use MPEG2 hardware encoder.Originally Posted by oldfart13
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
There's no doubt that a stand alone is faster. That is why I tried them out.Originally Posted by oldfart13
Although some have had great success with them, I think i'll wait till they improve. I did try 4 of them out. It's not like I tried 1 and said the heck with this.
I have a pretty fast PC (P4 2.5 ghz, 1.5ghz Ram). It takes more time to encode (if you don't have the Mpeg2 hardware encoder like donpedro stated) but at least you can prepare some nice professional looking menus through PC authoring. I think it will be a while before you can do that with a standalone if at all.
SONY RDR-GX7 FIRMWARE available for GX7 ?
By johnnyelectron in forum DVD & Blu-ray RecordersReplies: 14Last Post: 26th Dec 2009, 15:24 -
Sony RDR-GX7
By joecass in forum Newbie / General discussionsReplies: 3Last Post: 16th Dec 2009, 18:53 -
Is Sony RDR-HX720 compatible with Sony HT-SS2300
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2008, 09:14 -
Sony RDR GX7
By Macdon22shippTWO in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Sep 2007, 11:55 -
RECOVER DVD - Power Failure Sony GX7 ?
By johnnyelectron in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th May 2007, 11:13
