    Jan 2003
    Manitoba, Canada
    Hello, I'm looking to edit a dvd in uncompressed format....i just want to be able to split the files, join them, add transitions, text and audio.
    What would you reccomend as the simplest to use?
    I also want to save in uncompressed format!
    Jan 2003
    Manitoba, Canada
    bump, for some reason its not showing this post in the forum. Let's see if this post makes it work!
    I'd also like to add the price/value for the $$$ is not a problem...i just want to know what is the simpliest for what i want to do..i dont need a lot of features!
    Jan 2003
    Manitoba, Canada
