I got a huge problem..
When i´m using Tmpgenc and trying to demultiplex a movie that contains 2 or 3 files, sometimes it wont demux all files, maybe just the two first and the half third one.
Could someone tell me why ??
//hampe[/b]
There's probably something wrong with the ones that TMPGEnc fails on...
/Mats -
ok. but it happens pretty often.
And its nothing wrong with the movie, because before i demux it, it works perfect to watch at..
But maybe I just have to download it again.. -
Yes. I'd say it happens about 9 times out of ten for big AVI/mpg files donloaded, specially using P2P software like KaZaA...ok. but it happens pretty often.
That in itself tells you absolutely nothing about the integrity of the mpg (or AVI). These formats and their viewers are created to be very fault tolerant. Encoders (and multiplexers) are not.it works perfect to watch at..
/Mats -
If you have joined mpegs to create one big one, then you may have issues demuxing. Try mpgtx. It often succeeds where others fail.
MKV Demuxing Problems
By Justin123 in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 02:33 -
Demuxing DL problem
By calanda in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 00:52 -
Demuxing question
By gouletjo in forum Authoring (DVD)Replies: 4Last Post: 16th Feb 2010, 00:18 -
Demuxing
By ckurowsk in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2008, 18:04 -
what to do after demuxing?
By azizbhimani in forum SubtitleReplies: 2Last Post: 24th Feb 2008, 22:39
