I just converted a Divx into an Mpeg2 file, but the file is now a massive 2Gb in size, can I use nero and burn this as a normal DVD or SVCD disc to play in my stand alone DVD player?
Or do I need to split the file into smaller parts?
Yes, make sure the MPEG file is DVD compliant (check the DVDR article top left).
Hello. -
Before you just burn the MPEG2 onto a DVD and try to play it, make sure that your DVD player can play raw MPEG2 files. If it cannot, it must be authored first, creating your IFO/VOB/BUP files, and they must be in a VIDEO_TS folder.
Will Nero 6 do this for me if I use the wizard and tell it I want to make a DVD?Originally Posted by andkiich
No you'll have to use an auhtoring tool to build the DVD structure. Once you have the structure built for the VIDEO_TS folder, you can burn with Nero using the DVD-Video option.
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Shrink DVD to 2GB or Less
By pandemonium in forum DVD RippingReplies: 18Last Post: 7th Nov 2009, 01:34 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20 -
Any DVD player that will play divx files larger then 2GB?
By David9799 in forum DVD & Blu-ray PlayersReplies: 27Last Post: 9th Nov 2007, 11:53
