Greetings,
I know this is not good to put data to the maximum of the DVD capacity. But I am curious to know and I would like to do some testing.
Can someone tell me EXACTLY what is the maximum capacity in KBs (i.e.: 4464MBs= 4,571,136 KBs seems to be the number used by most softwares) of a DVD+R and a DVD+RW? I think this is not the exact same thing for each different format.
I saw different answers from different people, but I would like a confirmation.
Thank you
Results 1 to 11 of 11
It all depends on whether you're counting a megabyte as 1,000,000 bytes, or counting correctly. (1,048,576 bytes)
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
from the glossary:
DVD-5
DVD-5 is a single sided single layer DVD that stores up to about 4.7 GB = 4 700 000 000 bytes and that is 4.38 computer GigaBytes where 1 kilobyte is 1024 bytes(4 700 000 000B/1024 = about 4 589 843KB/1024 = about 4485MB/1024 = about 4.38GB) . Video DVD, DVD-R/W and DVD+R/W supports this format. Often referred to as "single sided, single layer". DVDRhelp DVD information
dvd+r and dvd+rw capacity - same standard.Always check helpfiles/instructions before leaping... -
wonder if Jestak ever thought of searching for it? amazing what you can find that way....
How Big A Boy Are Ya? -
Actually the plus is 6MB lessOriginally Posted by rcb
Blank DVD-R/W 4,489MB 4,706,074,624 bytes or 4.383GB
Blank DVD+R/W 4,483MB 4,700,372,992 bytes or 4.377GB
(source http://mrbass.org/dvdburn ) -
Greetings,
(Yes, I searched, and like I said, there are different numbers. I could have posted the different numbers, but I wanted "objective" numbers.
DVD-R/W 4,706,074,624 bytes
DVD+R/W 4,700,372,992 bytes
Are the most credibles numbers I found. But some people said the +R and +RW are holding a different number of bytes.
Thank you for your help! -
Greetings,
(I think my last message did not go through, so I'll repeat it)
I think DVD Shrink (or recode) has 4464 MBs pre-set to fit the DVD. So, does that mean the maximum would be in fact 4482?
thank you -
Greetings,
Thank you for the link, I already read it, but it made things clearer now. To recap, here is what I understood:
- A disk can hold 4,700,000,000 bytes maximum per the industry.
- The softwares say 4464 MBs maximum: 4464*1014*1024= 4,680,843,264
- The message board says you can have a maximum of 4482 (4483 - 1 MB) on disk: 4,699,717,632
Of course, the encoding softwares are doing an approximation, so in fact, for a dvd, you might set the target at 4500, for example, and it will give 4482.
Another quick question: I always create an ISO image (Done by IMGTool) from the VIDEO_TS folder. Must I base the maximum assumption from the VIDEO_TS folder or can I base it on the size of the ISO image?
Thank you -
Greetings,
I did some testing yesterday and here are my conclusions:
I used DVD+RW disks.
I used Nero Recode and DVD Shrink. I used 4 different movies:
- Babylon 5 season 1 disk 2
- T3
- Resident Evil
- Ice Age
I set up both softwares at 4482.
Only Ice age had under 4500 9When I removed the normal screen track), so no compression. Everything worked fine.
Then I removed 2 tracks on the Babylon 5 dvd and the compression was at about 98% (almost nothing). Both with Recode and DVD shrink the end result was 200 megs over and it was impossible to write. Then I removed some stuff to make the compression at 88%. No more problem.
So, I concluded that if I have a very low compression, it may be a problem. I did the same thing with T3 and resident evil, removing tracks. Both gave me the same problem. Around 200 megs over. I tried also with Black hack down disk 1. I removed some tracks to have the compression ration over 95%. Same problem, 100 Megs over.
I hope this small test will help some of you.
Thank you
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 10:49 -
Maximum 16:9 resolution for DVD?
By Paul Hetherington in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2012, 05:29 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 05:52 -
Ulead DVD MovieFactory 6 not making maximum use of DVD space
By GSP_87 in forum Authoring (DVD)Replies: 6Last Post: 6th Nov 2009, 05:54 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 10:23
