  1. hi
    I'm making a project in Scenarist, and i want to have a menu, with 3 choices
    1 - Robert Song
    2 - JC Song
    3 - Sandy Song
    i want that when you select each choice, the song (acording to the selection, ex Jc.wav) keep playing until you select another or until you exit the menu (or until the song finish of course)
    i saw this in the superman dvd
    when you can listen songs from the movie
    thanks a lot!!
    cheers
    -StK
    Increase knowledge, increase sorrow.
  2. adammmmmmmmmmmmmmmmmmmmmm
  3. To achieve something like this, what you actually have to do is make each one of those highlights link to a menu with an identical background still (or perhaps with a "now playing..." indicator, but one that plays one of the selected audio tracks. (Still with audio, the way to accomplish this depends on your authoring program) Once it's over, or if the user selects "back" or another song, it should link to another menu.
  4. thanks a lot kuranuk
    it works!
    thanks
