  1. Trying to make some back-up's of some of my more favorite DVD movies. The problem I have is when I put the DVD in the drive, it does not read the folders/directories on the DVD.
    I have it set to region 1, so that isn't it.
    The drive itself does work, I am sure of it. I can place a PC game in it and it works beautifully (reads the game/installs).
    I have all the drivers and possibl;e updates I can get (at least i think so).
    The drive I have is a Pioneer 106-D.
    If there are updates for it that I may have over-looked, please post the url(s). Thanks in advance!
  2. Post Update: I just tried to put in a PS2 game (DVD), and it reads its files. Although putting in a XBox game, no files are read.
    Any help would be appreciated. Thanks!
    Nov 2003
    Houston, TX
    the discs are copy protected, u hafta have special software to decrypt the dvd, dvddecrypter, or if u just wanna make a backup of the dvd to another dvd, try dvdshrink, its a great program.
    hope this helps, josh
    [EDIT] also, i think xbox games are read from the outside in, whereas pretty much everything is from the inside out.
