I have a DivX file that has 5.1 AC3 audio and SUB and IDX files for subtitles. I have never dealt with DivX files like this and don't know where to begin to convert this to either VOB or MPEG-2 files.
I used Virtual Dub to extract the audio and video and am using TMPGEnc to convert from AVI to MPEG-2. Now, what do I do with the subtitle files? The audio is Cantonese so I have to have the subs.
I thought I could use SubRip to convert the SUB files to SRT files, but I get an error message "unsupported file format".
Thanks.
"Can You Dig It!"
you should be able to demux the subs using virtualdub. check the stream list. select the sub stream and choose demux.
convert the idx file to srt or sub using subrip.
use vobsub to permanently add the subs to your avi file.
convert the avi file using tmpgenc
load audio and video into dvd authoring program
burn authored files to dvd. -
If you want "real" DVD subs (selectable), you can use sub2sup, and then author with IfoEdit.
/Mats
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 03:25 -
How to extract subtitle stream in .divx file and save as idx/sub
By newnews in forum SubtitleReplies: 1Last Post: 29th Jul 2008, 14:36 -
How to join the idx/sub languages ripped separatedly into just one idx/sub?
By Talayero in forum SubtitleReplies: 5Last Post: 29th Mar 2008, 09:58 -
avi to dvd with idx/sub
By wingfan in forum Authoring (DVD)Replies: 8Last Post: 28th Feb 2008, 23:17 -
DVD to sub/idx or .sup to sub/idx - How can I do either?
By rock_king_my in forum SubtitleReplies: 4Last Post: 10th Aug 2007, 10:01
