Hello,
I believe the solution to my problem might be simple, but I'm not experienced enough to know what it is. Here's the lowdown:
I enjoy the show "Whose Line Is It Anyway" and I've been capturing it from ABC Family quite often as of late. I use a Leadtek 2000 XP at 10 bits and I capture to MPEG-2. I then convert to DivX via VirtualDub-MPEG2. I believe I either have dropped frames or bad frames when I capture, but in the past I've been able to fiddle with the frame rate and audio interleaving in VirtualDub and get the audio and video synced, either pre or post processing.
The last time I captured (Friday), I ended up with an hour long 3GB capture file, as usual. However, the audio and video I could not get to sync in VirtualDub. The funny thing is, though, that if I play it in BSPlayer the sync is absolutely PERFECT, the video is smooth, and in FlaskMPEG the sync is close to perfect! It seems the audio and video rates aren't "locked" as they should be. The lengths of the two streams are the same. The only way I can get them to "lock" is reprocessing through TMPGenc, but that degrades the quality and the MPEG-2 gets a little jumpy/choppy. (But the sync is perfect, and I can get to DivX via VirtualDub-MPEG-2.) Anyway, I'd like to be able to process directly from the captured MPEG-2 and go to DivX.
Here's some questions:
WHY do the MPEG-2 video and audio streams maintain PERFECT sync in BSPlayer? Is there a program out there capable of reproducing that "perfect sync" to allow for conversion to DivX without actually completely reprocessing/reencoding the video? (In other words, a program that just "locks" the audio and video permanently as BSPlayer transiently does.) It doesn't make sense to me that a video & audio stream can play in perfect sync in BSPlayer and not be able to be processed in perfect sync using some program out there! If it's in sync in BSPlayer, why can't it be in sync elsewhere? My guess is that there are some dropped frames and BSPlayer smoothly accounts for that. Isn't there a piece of software out there that can do that? Preferably free?
Thanks for any help you all can give!
P.S. I know this must be possible because FlaskMPEG gives near-synced audio. I need something easier to use and less buggy, though. Either a program that fixes the audio/video streams so I can load it into VirtualDub-MPEG2 OR a program that can process directly to DivX with the streams in sync.
Spectroelectro,
ReStream looks like a great program...but I'm not exactly sure what options in the program I need to use in order for it to work. If you have suggestions, I'd appreciate it.
As for VirtualDubMod_Sync, does it capture to MPEG-2? I've found I get the best quality by capturing directly to MPEG-2 and then encoding to DivX. Thanks for the suggestion, either way.
Auto GK conversion issues
By mespi56923 in forum Video ConversionReplies: 35Last Post: 18th Jun 2009, 00:28 -
Conversion and playback issues.
By tooham in forum Video ConversionReplies: 1Last Post: 17th Feb 2009, 11:18 -
By tooham in forum DVD RippingReplies: 1Last Post: 17th Feb 2009, 11:15 -
sync issues with DVD to DivX conversion
By snafubaby in forum DVD RippingReplies: 12Last Post: 24th Dec 2008, 03:10 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 09:32
