I have used TMPGEnc to encode an avi and have sucessfully produced a standalone-compliant DVD.
I have four smaller avi files. I would like to get them to one DVD.
I have tried to join them, but have not been able to because of differing stats (frame rate, size and bitrate).
Do i have to encode each seperately or am i able to load all four into an app to encode all four together.
i have looked in guides, but i cannot find one for concurrent multiple encoding.
thanks in advance
Zworg2
Encode each AVI seperately then use TMPGenc DVD Author to include all clips on one DVD. You can add menu and chapters for each clip if you want to. Easy programme to learn.
TMPGEnc has a Batch Encode function which will perform consecutive jobs. You have to set up each one individually though. In the last screen of the project wizard you select "create another project for batch encode," or if in the main screen just save project.Originally Posted by zworg2"Art is making something out of nothing and selling it." - Frank Zappa
thanks...
its not the authoring end that i have issues with....
its the fact that its gonna take ages to encode all four, and will require multiple user input (even if only to click a button!)
thanks ZippyP i'll give the batch encoding a go.
Zworg2
Batch processing AVI to MP4 (H.264)
By Ahari in forum Newbie / General discussionsReplies: 39Last Post: 10th Apr 2012, 13:52 -
Batch Processing
By keefytee in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 7th May 2011, 05:41 -
Unanswered questions on processing and compressing DV-AVI
By sd_smoker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 40Last Post: 2nd Jul 2008, 17:31 -
Batch processing .AVI
By R2 in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 21:34 -
Batch Processing
By ruggie_uk in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 19th Jul 2007, 07:04
