Results 1 to 17 of 17
  1. hi
    i read in a previous post how to set up the bitrate for a mpg1 unlocking the fild in TMPGEnc (loading a template)
    but if i set to a lower bitrate i find no change in the filesize of my new mpg
    but if i set it to a higher bitrate it works fine...
    anyone knows why?
    i have TMPGEnc last version
    TMPGEnc-2.521.58.169-Plus
    Increase knowledge, increase sorrow.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Be sure to set it to VCD (non-standard).
  3. when i use the unlock template
    to unlock the grayed fields (bitrate etc)
    i get MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps
    its this what you mean?
  4. Be sure to set it to VCD (non-standard).
    it works!
    dont know why but, setting to vcd non standard made it work
    thanks
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
  6. Increase knowledge, increase sorrow.
  7. i have to get back to my older version because sometimes i donwload video files and When I'm playing them in media player 9, some of them will only show as being a short clip (usually under a minute) when they may be much longer.
    The whole thing plays but there is no way to know how long they are or to seek ahead...
    the only way i found to fix it is reencoding them, but with the new version:
    TMPGEnc-2.521.58.169-Plus it only enconde the minutes that shows in media player (1 or 2 minutes)
    dont know why...
    pls anyone has a clue?
  8. anyone?
  9. noup?
  10. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    You have a corrupt mpeg file. This can happen when a large mpeg is cut/joined. You can try a couple of the mpeg repair tools in the tools section. But I've found that usually MPEG-VCR's gop fixer works pretty good.
    You may want to also try VirtualDub (for Mpeg1) or VirtualDub-Mod for mpeg1/mpeg2.
  11. i dont like womble mpeg-vcr very much, 'cause once i cut something with it..
    if i want to re-encoded the file later on with TMPGEnc..
    it takes ages..
    and i dont get sound...
    dont know why, but this happens everytime i use mpeg-vcr with an mpg
  12. Increase knowledge, increase sorrow.
  13. one last time
    dont know why...
    anyone??
  14. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    The whatever you're downloading is corrupt, that's the most probable answer.
    /Mats
  15. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    You need to frameserve it to TMPGenc if you wish to re-encode it!
    Use dvd2avi if it is mpeg 2 or virtualdub if it is mpeg 1 for this.
  16. mats.hogberg Posted: May 12, 2004 18:52
    /Mats
    well, the file its not corrupt, maybe encoded with poor audio codec, (I read somewhere, that could be the problem)
    anyway i was able to see the video with no problem, before i install my adobe products, (premiere, AfterEffects, etc)
    but after, when i play the video, its only appears like a 2 minute video..
    if i re-encoded with a older version of TMPGEnc it plays fine..
    (but i have to reencoded, lose quailty, time, etc)
    but when i try to re-encoded, with the last version of TMPGEnc2.521.58.169-Plus it only enconde the minutes that shows in media player (1 or 2 minutes)
    so basically my question is...
    there is a way to reverse the changes made by adobe, (i try to unistall them with no luck) so i can watch the whole video in media player..
    or
    to re-encode it in the last version of TMPGEnc (2.521.58.169-Plus) without having to frameserve??
    thanks a lot
    -StK
  17. Member DJRumpy's Avatar
    Dallas, Texas
    You could have a codec conflict. You can disable individual codecs using the control panel. Select 'Sounds & Audio Devices' or 'Sounds & Multimedia' (depends on your OS). Then the Hardware tab. Scroll throught the list until you find the Video codecs. Double click the Video Codecs, or highlight it and click the properties button. Click the PROPERTIES tab. You should see a full list of all video codecs installed on your PC.
    To see what codec is being used to decode your video, use AVICodec (find it in the TOOLS section). You can also use MPEG Properties (also in the TOOLS section) to view MPEG info. The AVICodec tool title is a bit misleading. It will report codecs for almost any kind of audio/video input.
    Impossible to see the future is. The Dark Side clouds everything...
