  1. i have a DVDR and im trying to copy it.
    I've tried just 1:1 with Nero, but it doesn't work
    I've tried using DVDDecrypter and ripping it, but it gets to like 39% then stops. Does anyone know how to fix this.
    The disc isn't scratched
    Feb 2004
    WI.
    Have you tried just copying the files from the disk to your hard drive?
  3. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    are you getting an error, whats the error ?
    is it having problems reading the disk,
    i would try decrypter, iso buster , copy and paste, dvdshrink, if they didnt work i would probably give up
    Feb 2004
    WI.
    Would'nt the movie on the DVD-R already be decrypted? So all you need is the files right? Try opening the disk and copying the files. May work that way.
  5. If you haven't already, try ripping/copying with your DVD Burner, instead of your DVD-ROM drive ..... these can be more tolerant.
