I just bought 50 Ridata/Ritek, 50 Ritek and 50 Ricoh discs. Both the Ridata and Ritek discs have scratches on the surface, but the Ricoh discs looks perfect. I also found out that the Ridata didn't looked like they are perfect burn't because the dye looks a bit blotchy. So is this bad Riteks or is this what u can expect from ritek those days?
Results 1 to 19 of 19
i just recently bought a test of 2 Ritek G04 DVD-R's b/c my Sandy Yang were not burning right - They were freezing at the end of movies -
the weird thing is some of my sandy yang worked, but most didnt -
the other weird thing is that with me test of 2 ritek's 1 came out perfect and the other didn't - it did the same thing as the sandy yang did - freeze at the end - now i didn't notice the purple smear of dye until after - i'm not sure if that was there before or not - i updated my pioneer 105 firmware, nero software, and dvd shrink - so it can't be that - it has to be the media or my pioneer 105 -
so to answer your question - i'm not sure - maybe it is what to expect now - -
You hit the nail on the head.Originally Posted by EspenJames B Elder
A lot of the guys here seem to have been unluck with Ritek recently - I use them pretty much exclusively for my own work and have not noticed any degredation in the quality. Perhaps the UK are more discerning customers and they know they won't get away with slipping their cast-offs in our general direction... ?
Just a bit off topic, if I had a Sandy Yang I'd probably go and see a doctor...
Snap...Originally Posted by garryheather
Mind you i only use the printable one..
It seems to be the "Ridata/Ritek" ones that are the problem.
Not bothered by small problems...
Spend a night alone with a mosquito -
yeah, i always used unbranded printable G04's from SVP. loving them.
Couldn't that also be chalked up to bad (re)packaging?Originally Posted by Espen
Discs that appear to have a perfect surface yet burn poorly would cause me MUCH more concern than the obvious reason for them burning poorly.....a scratched surface. -
does any1 know any details about the Ritek that amazon are selling? they're going for 35$ per 50 but I've heard some bad rumours here about them being re-packaged sth...
With all due respect... and there is respect... -
Recently I had bought 100 Ritek and 100 Ridata. Both had loads of coasters (>30/100) :P
can someone now believe what I am saying here about RMA Ritek? and some credit of what I am saying.
https://www.videohelp.com/forum/viewtopic.php?t=225634&highlight=
THANK YOU!! -
No.Originally Posted by 500AXDon't sweat the petty things, just pet the sweaty things.
Just to add my own $.02 here, a co-worker purchased the 50-pack purple wrapper, branded/arrow logo D2 from newegg, and I split the pack with him. He has burned 8 with no problems on a NEC-2510. I have tried 2 on a NEC-1300a, and both failed to write. I also noticed a small lighter ring a few cms in. (Also, they smell funny!)
So there you have it! What works for some, doesn't work for others. I won't say they're crap, just that they don't work in my burner. While they may cost more, I'll stick to my Sonys, TDKs, Memorex, and Fujis. Never had any trouble with any of those.
When I do, I'll quit buying those too.
NO.can someone now believe what I am saying here about RMA Ritek? and some credit of what I am saying.
In case you didn't catch that....Originally Posted by 500AX
No
No, the rumor has been posted as a "friend" at office depot, at office max or at ritek....classic urban myth.Originally Posted by 500AX
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
my new pc......not bad...
By khalid81 in forum ComputerReplies: 4Last Post: 29th Sep 2009, 16:41 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 10:07 -
Bad Sectors?
By whoisquilty in forum MacReplies: 8Last Post: 19th Apr 2008, 20:09 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45
