i have always used adobe premiere to capture dv video from my camcorder. but i had a problem with it capturing to my new external drive. so i tried DVIO, and it works great. but i have one question: what is the difference between type 1 avi and type 2 avi? ive captured using both and havent noticed any differences. which one should i be using?
Check the 'Glossary' :https://www.videohelp.com/glossary?D#DV
DV2 is needed for Virtualdub and works well with TMPGEnc. If you have DV1 there is a converter to DV2 in the 'Tools' section. -
thanks, i knew it was in the glossary somewhere. i must have skipped over it
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 14:52
