  1. i have a sblive 5.1 card and creative 5.1 speakers.sometime when playing either music cds dvd or other media i get really bad crackling nosies from my speakers.sometimes its ok on cd then the same cd will playback with problems.this is the same for all other media formats.anyone help?
  2. Possibly try an older or newer version of drivers? There was one time I had a similar problem. Using an older version of the drivers fixed it.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  3. its not a loose wire i have checked everything.the speakers have only just sarted to play up they work perfect when i first installed the card.where would i find older drivers for it creative don`t have them neither does driver guide?
  4. now found out that i get a small crakling noise when i click my mouse then when i play a file it gets worse`s but only out of the right side speakers ten after a while it goes then comes back?
