Sorry to ask in a new post But i cannot for the life of me do this..
Can some1 PLEASE right a simple step by step way to do the following.
I have an AVI XVID 700mb
I want to put it on a dvd to watch indvd players!
Its 23.976 and i need it 25fps so somehow i need to change the Framerate.
Have tried various ways and none with success please tell me how others have done it with no jerks or sync problems
thanks
The standard method is to resample the audio to make it match 25 fps
and then just tell the video it is 25 fps . This just speeds it up 4%
Usually it also needs to be resized to 576 vertical for PAL , which
requires a re-encode. -
And what program would u use to do this?
I tired to take the audio via virtual dub, change the frame rate of the avi to 25 with aviframeratechanger then encode using mainconcept but it put it out of sync
i adjusted the length of audio to exact same of the video -
Divx and xvid are always a pain in the ass.
Find out what kind of audio it is. Vdub may be able to save it as a wav.
then use Besweet to resample it to an AC3 or a MP2 at 25 fps
Then frameserve the video with Vdub to TMPGenc which can resize
and encode to PAL MPEG2 . Set "do not frame rate conversion"
then you just put those into an authoring program. -
Ok , sorry im still new to this and trying to find the best way! I dont get along with tmpgenc but i can learn and frameserving i find hard!!!!
So i open my 23.976 in vdub, and extract the audio as a wav .
Use besweet to resample at 25fps
then frameserve to tmpgenc???
And i shud have a smooth running 25fps mpeg2?!?!?!
Frame Rate Conversion
By roberto188 in forum Video ConversionReplies: 17Last Post: 5th Mar 2011, 10:11 -
Slow Frame Rate
By tobymac in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Mar 2008, 13:12 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Frame rate conversion
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 13:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
