I shrunk one of my dvd's and was wondering if I could watch it completely without having to burn it. I was thinking I could use nero to make an image of the dvd, and then mount it on the image drive and watch it but I couldn't figure out how to create an image of it? Any Help?
Just open those shrink files with your dvd viewing program. It should let you choose them on the HD.
In Nero burn to the 'Image Drive (DVD)' from the recorder selection. This will burn an ISO DVD onto your HDD. Then delete the original DVDShrink output files (you will no longer need them).
Or from DVDShrink (latest version) select Nero Image drive as the burner
Or just open the files with WinDVD (or similar) with the 'from file (for mpeg/mpeg2' or 'play DVD from folder' option.
Or just rip the main movie to the HDD with SmartRipper or DVD Decrypter and then as above.
What is it you want to do....exactly? -
Just open up up the vob files in windows media player. Usually it's the first vob in the the folder. What dvd shrink creates is basically a playable image of the disc.
Actually, WMP is a bad choice for playing VOB files. They just don't display properly (you'll think something's wrong with your VOBs).Originally Posted by j-a-w
Use this:
C:\WINNT\system32\dvdplay.exe
Getting a 720p output after burning
By purplecds in forum Blu-ray RippingReplies: 8Last Post: 23rd May 2010, 22:17 -
Ripping with SHRINK then BURNING with IMG burn
By efiste2 in forum DVD RippingReplies: 10Last Post: 17th Apr 2010, 01:39 -
GUI for DVDauthor - Fit/shrink output to 4.7G DVD
By pannayar in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2008, 23:49 -
[Solved] Cannot watch frames in input/output video windows before cutting
By moogly in forum EditingReplies: 1Last Post: 27th Jun 2008, 09:48 -
burning with dvd shrink/imgburn
By angryassdrummer in forum Authoring (DVD)Replies: 4Last Post: 7th May 2007, 16:44
