Hi, I'm cofronted with the following problem.
I have a DVD that is slightly damaged. It still plays in a stand-alone player without missing a beat, but when I try to use it in my DVD-drive, the movie halts. Trying to make a copy blocks as well (I tried Smartripper and DVD decrypter in IFO and ISO mode).
So I was wondering, is there a way to make a good copy of this movie (other than sending the signal over a capture card) with my stand-alone player?
Just copying the main movie is enough, I can do without the menu and theres no extra's.
Thanks.
Are you just trying in your DVD burner or do you have a DVD-ROM that you've tried it in as well? If you only have your burner you may have better luck with a DVD-ROM reading the disk instead. If you can get a hold of one to use try that. Otherwise maybe try downloading all sorts of copy software and try different ones. Some do things better then others. For example DVDX Copy is supposed to be able to fix damaged DVD's when ripping them.
Good Luck.
It's sort of funny though. My sons SpiderMan movie is extremely scratched and scuffed up. It will not play smoothly in my Stand alone player or computer. It skips and freezes constantly. But I am able to rip in and make a perfect copy that plays flawlessly. Go figure
Whats a simple software DVD player that just works !
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 15:20 -
trying to fix a scratched dvd, works on pc but not player...
By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 09:02 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 07:22 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 02:54 -
my dvd-lo that works on Mac, not in external player
By oldblues in forum ffmpegX general discussionReplies: 8Last Post: 11th Jul 2007, 03:22
