hey i just wanted to know if someone knew what burners supported 99 minute cdr burning i've tried it on a yamaha and it goes to the end and gives me a track error![]()
thanks
LG electronics works for me. The model I use is the 8X4X32 LG CED8080B. Got mine from compuvest.com for about 70 bucks. Works great.
LG's newer model is out 12x8x40 all the same feaures, just faster. I paid $75 at BestBuy.
You can check my list of CD ReWriters to see which one best suits your purposes
http://www.sefy.dns2go.com/cdrewriter.html
as far as I know and got also reports from users that the Lite-On series of burners can do 90 and 99min CDR without a problem, latest model costs around 95$ and is 24x10x40.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
HP9150 for $90 at walmart burns no problems all the way to 99min. using CompUSA 99min. CD-R's. I use NERO 5535. Plus its not picky on CD-R's, you can burn any you throw at it.
thxkid, the HP9150 which you keep recomanding, if i'm not mistaken (corrent me if i'm wrong) is a 8x/4x/32x drive which may cost at Wallmart 90$, but on most other places it cost around 140$, it's a very old burner, and very slow, so why spend that much, when you can add 5$ more and get a 24x10x40 for a newer burner which would atleast be supported for awhile with new Firmware for more support. (has anyone seen HP releasing firmwares?)
Best Regards,
Sefy Levy,
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 09:26 -
Recommendations for Blu-Ray Burner with LTH media support
By TBoneit in forum DVD & Blu-ray WritersReplies: 12Last Post: 19th Oct 2010, 16:43 -
Last Minute TV Advice Needed
By AuroEdge in forum Off topicReplies: 0Last Post: 13th Feb 2010, 18:47 -
Best way to concatenate nine 10-minute Flash videos?
By Verlager in forum LinuxReplies: 18Last Post: 27th Apr 2009, 01:28 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 17:50
