Is it possible to copy a dvd-9 and remove the last part of the movie (trailing tittles) and optionally keep the menu and some extras.
I've tried instantcopy, but you can't remove any part of the maijn movie. I also tried dvd-shrink. You can remove a part of the movie (re-author), but so far as i know you will lose the menu.
heja!
use DVDstripper... on the net you can find several guides about this program. I just burnt on DVD with it... and this one turned out great...
I also read but not shure, about DVDlab... look on the forum... i possitive you will find a satisfing awnser!
later![ I'm not talkin' to fast, your just a slow listner ]
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 18:04 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
remove audio part of mpg
By zmartha in forum AudioReplies: 5Last Post: 19th Oct 2009, 18:51 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
Remove duplicate part of a video
By PharmBoy in forum EditingReplies: 3Last Post: 8th Jun 2007, 23:35
