It plays DVDs fine but when it comes to burned svcds it won't read it correctly. is there a firmware i need to get? or is it the way i burned (i burned usually around 24x)? or is it the cdr media? I don't think its the media b/c my friends norcent dvd player plays the svcds that I burned. Please help!?!?!?
TRy different disks and try burning slower. If that doesn't help then try lowering the bitrate when you encode your mpeg.
JVC (GR-DVF21) DV in/out - not showing on DVD player ?
By Roamingdoc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2011, 10:46 -
JVC DVD player flashing, otherwise dead
By lboiv001 in forum Media Center PC / MediaCentersReplies: 0Last Post: 9th Dec 2009, 01:13 -
Frame Skipping in Media Player Classic
By Sootmouth in forum Newbie / General discussionsReplies: 0Last Post: 7th Oct 2009, 19:00 -
WD TV USB Player 5.1 Audio Skipping
By njsges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jan 2009, 02:31 -
DVD Player Skipping
By WuPhilly in forum Newbie / General discussionsReplies: 4Last Post: 12th Jun 2008, 10:33
