I never had that problem. I use multiple tracks when I put TV shows on a DVD and if you select PLAY ALL (on the main menu) it should play through the whole DVD with only a very slight pause where it switches from track one to track two etc.Originally Posted by ams30gts
At worst it should kick back to the main menu after track one where you then can pick track two
- John "FulciLives" Coleman
Results 31 to 32 of 32
nm. i usually dont use menus. but try it.
edit.
still out of sync on the 2nd track
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
CCE Pal to Ntsc conversion-NO AUDIO
By ranosb in forum Video ConversionReplies: 9Last Post: 2nd May 2009, 05:45 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 19:15 -
Pal to NTSC with CCE?
By Sephiroth666 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2007, 22:45
