Hey !
I want to author a SVCD. With BFinder I computed
a bitrate to fit the video stuff on two CD.
But ... where to the hell do I set this bitrate
in FlaskMPeg ???
Any hint ?
Thanks !
Andree
Set the bitrate anywhere in the MPEG plugin. Since I don't know, which one you use, I can not give you a more exact answer.
option> select output format: bbmpeg
output format options> video stream settings tab: bitrate
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
