Strange thing has just popped up. First, I use a DVC-150 (Which came with quickstart 8) to convert all my old home vhs tapes to DVD. It has worked fine and I have converted over 30 perfect DVD's. Of the 30 made a few needed to be split and joined for time sequence needs. I used TMPGENC to do this and it worked fine. I was able to split and join to my hearts content. Now it seems as If something has changed as I can no longer split or join the captured mpeg file. The files look fine and play fine, but they simply will not load into any split/join program. Instead I get an error message saying there has been a floating decimal point division by zero error.
I have tried with TMPGENC and a couple of other join/split programs and each give me the same error. Why now would I start getting these errors when trying to edit? Could a codec or another program be conflicting? I just find it strange that I have been able to do it before and now all of a sudden I can't do it at all.
Any help appreciated.
Directshow priority? 2nd link below.
"Art is making something out of nothing and selling it." - Frank Zappa -
Try cutting and merhing with Mpg2Cut2,
which is designed to accept a wide variety of Mpeg-2 files.
Download the latest version of Mpg2Cut2 at
http://www.geocities.com/rocketjet4/
For cutting VOBs, I recommend the following::
- "menu - Output - Preamble - MAXIMUM"
- Also use "PVAStrumento" from Offeryn if cutting multiple clips..
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47
