Some DVD movies come with both Widescreen and Full screen versions. Is it possible to select which version during backing up so as to reduce the space required on the DVDR?
DVD Shrink Re-Author mode will work fine for that, just pick which one you want.
Or use DVDStripper (now freeware) to strip either widescreen or full screen version (your choice) and still keep the menu.
Simple question...simple answer. You do a few of these and it gets easier and easier.Originally Posted by oldlag
Reauthoring with DVD Shrink gives you only a movie only backup. DVD Stripper strips the unwanted version but you still have the aspect ratio menu to contend with.
Take your leap of faith and you'll never look back.
@DoubleShadowIce
Unfortunately, I haven't really had time to play around with it (too busy at the moment).
One of these days, I'll have to sit down and go thru it step by step (looks terribly complicated though
Thanks again for the tip.
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 18:23 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20
