I am trying to take avi to DVD here. I have 22 avi files, all roughly 45 minutes in video, making it a little around 200 megs each. I tried to combine some into one file (using the ffmpegX). I thought that I would probably use 3 per joined file (to make seperate DVDs) and was first wondering if this was the max amount of episodes that I would probably be able to fit on a disc? Secondly, when i am joining the episodes, i have a file that ends in .temp. Do i erase that everytime i want to join another file to make it like i am joining two avis? Thirdly, when I went to get info on the filesize to see if it had worked, it appeared to, however, when i set it in toast, it said that it was only 44 minutes, like the size of one episode. So, does anyone have any suggestions?
Results 1 to 9 of 9
Assemble your crew, I'll meet you outside.
What kind of FILES are they?
AVI doesn't say enough, as the AUDIO VIDEO INTERLEAVE format is a catchall wrapper for widely varing formats
f you have QUICKTIME PRO installed, it should join your AVI's with no RE-RENDERING...
Unless they are MPEG-4 -
I'm curious why you don't just drag a couple files to Toast as individual movies? I don't think Toast will author more than 90 minutes of video unless it is already in MPEG form.
i tried using toast to convert 1 and 3 avi files, neither of them had sound. Now, i am currently trying to convert to DVD format using DVD Studio Pro, but is taking a long ass time. As far as the type of avi, it just says AVI movie. i will try quicktime pro if i can find it. maybe that will help out some? any other suggestions?
Assemble your crew, I'll meet you outside. -
an option i can offer would be to try just one of these files [before they are converted to quicktime able files] with mpeg2works
this should convert the .avi to .mpeg for you to then compile into a dvd image easily
but try it with just one and see.
you can get more info on the .avi if you open it with VLC and push command I -
Galactica, Is anyone putting out a CODEC APPLIANCE for the MAC?
Because he must be having difficulties because its not a "regular avi" but a DIVX or some other MPEG-4 codec that cannot be joined with Quicktime, or any of the MPEG-1 or 2-MERGE type tools..
*Codec Appliance - Info program that tells you what codec is used in a given file
Avi to DVD Problems
By RBCC in forum Authoring (DVD)Replies: 6Last Post: 9th May 2011, 14:55 -
Avi to dvd Problems on a mac
By Cruz240sx in forum MacReplies: 6Last Post: 19th Apr 2009, 19:47 -
AVI to DVD Problems
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2007, 01:23 -
Two problems with avi -> DvD ffmpg
By abassili in forum ffmpegX general discussionReplies: 17Last Post: 12th Jul 2007, 19:36 -
DVD to AVI Problems
By Harvey__ in forum DVD RippingReplies: 2Last Post: 31st May 2007, 19:04
