I recently converted a Divx 23.976 fps video to KDVD. I used pulldown.exe to do a pulldown to 29.97 fps. I observed that it causes jerkiness ONLY during panning (camera moves slowly from one direction to another). I think pulldown.exe is causing this and I want to know if there is an alternative program. I use the simple command line
pulldown.exe XXX.mpv XXX.m2v
Maybe I should be using more parameters, if so what are they?
Hi digicube,
I think that its safe to assume that instead of the pulldown.exe being to
blame here, I would rather blame the divX file, because this could just be
the result of someone else's poor encoding (or, poor choice of converting
to 23.976, as the source might not have ben w/in % reason ie, dvd2avi)
Your pulldown params were probably fine, just the divX source instead.
But, if the source is a low resolution ie, 352x240 (or had one of its fields
chopped off) this could also be the reason for your issue, cause 352x240
is not standard when trying to convert 23.976 to 29.970 w/ pulldown.
-vhelp
Hardcode to mkv
By BBQchicken in forum SubtitleReplies: 2Last Post: 16th Nov 2011, 22:38 -
-azid (-c normal) alternative when using azidts.exe to convert DTS to MP3
By onesikgypo in forum AudioReplies: 0Last Post: 7th Nov 2010, 05:46 -
Hardcode subs on .m2ts???
By LoveMyslf in forum Video ConversionReplies: 6Last Post: 15th Sep 2010, 16:28 -
Hardcode Subs
By Gh0st Rav3r in forum SubtitleReplies: 1Last Post: 16th Oct 2009, 16:47 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42
