Hello. I´m looking for a camcorder with FireWire capabilities and Sony TRV22 is a very interesting one.
I like to tape, edit on the computer, and then send it to VHS using the camera. Is that possible using this equipment? Can I send from Sony TRV22 to VHS?
And also, it is possible to capture FROM VHS to DV?
Thanks in advance
Adrian
You can send it to VHS but not via firewire. You can record to DV if your camera has VCR functionality, which the TRV22 does have.
Yes with the TRV-22 you can go both ways
you can capture from VCR ( a tape) convert it to DV
edit/effects/whatever and then print/export back to tape
Also a nice way to convert 8/hi8 tapes from older cameras -
Thank you guys, speccialy D_Knife, very clear and precise.
By the way and for the same price
1) if the Sony camera is NTSC and my original VHS tapes are PAL, can I send a PAL signal (I own a PAL and NTSC VCR) to the camera and capture to DV anyway? Passtrough capabilities allow me to do this without save to MiniDV?
2) I have a lot of MiniDV tapes recorded with and old JVC GRV10, no FireWire. Are them already DV format? Is just put them on the Sony and capture them to the computer?
Thanks a lot again -
1 I doubt it
My trv-22 is PAL and it chokes on a NTSC video signal from my VCR which is multi-format as are most devices here in Oz
2 if they are miniDv tapes then yes they are DV -
1. no PAL transfer via NTSC cam to VCR and vice versa. All devices have to be in the same system/format.
2. if video heads on JVC and Sony are perfectly aligned there will be no problem, however if this is not the case you will get blocky artifacts or you won't be able to extract the picture from the tape. Test your new cam be4 you buy with couple of old tapes.
EZCap(S-Video) vs Firewire to capture VHS
By Pepepaco in forum Capturing and VCRReplies: 9Last Post: 4th Dec 2011, 13:51 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 21:32 -
Audio clicks-converting VHS to DVD w/Canopus ADVC-55, firewire, iMovie
By Danae in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2010, 16:44 -
Mitsubishi HD-HS2000U - vhs/svhs out of FireWire port?
By mikejaz2 in forum Capturing and VCRReplies: 29Last Post: 5th Aug 2008, 22:28 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19
