  1. Hi guys Can anyone help me about multitracks and TSCV?
    I've tried to change my "xml" to point everything such as, next, time out, return to next track but still my APEX will play only first track and then stop.
    IF while I playing this multitracks CD then select 1 or 2 or 3 (bsn selection), this VCD will play to the end. I want it to be played perfectly in the first time when I hit "play" button. So I appreciate all the help guys. thanks
  2. Which model APEX you using?
    is this all one video that is stoping when it hits the second chapter or is it another video you just want to start after the first one ends?
  3. it is an APEX 660 8MM.
    yes it is another movie clip that I want it to play continuously, such as music video each song mean each track. Do you have a solution for me?
    I know I can do this with NERO without problem but i wanna do it with vcdimager (TSCV) this time.
  4. Are you creating menus?
    If you just want a simple multitrack VCD with no menus, you can just use "VCDImager.exe" as apposed to "VCDXBUILD.EXE" and the XML system -- i.e., do it the old way.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Regards.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    In that case, I wont be able to do entrypoints, right?. As far as I can remember I cannot make entrypoints to play in my APEX with editing cue file.
