tried about every option in TMPGenc, still the vido looks "blocky" - that is, the mpg lookes like a checkerboard.
the avi is fine
(using NERO, i compare the avi to the mpeg in FULL SCREEN)
anys solutions?
With all of the details that you have provided (none) it is very difficult to guess what is causing your problem. Generally, in an avi to mpeg conversion, blockiness can be caused by two things:
1. Upsizing the resolution from lower to higher. It's best to convert to a similar or slightly lower resolution as the source.
2. The bitrate is too low for the resolution, i.e. your bits per pixel count is too low. You can drop the resolution or increase the bitrate to compensate. Also, if file size is a restriction, using 2-pass VBR in order to better distribute the bits can help.
8)"Art is making something out of nothing and selling it." - Frank Zappa -
lke a said, i tried just about every setting. VCD bitrate, max bitrate for SVCD, capturea at 640x480,480x480,352x240, etc
when i convert DVD to (S)VCD, there is no "checkerboard"
from vcr rca connections to wintv pci card
VIRTUAL DUB: capture to single avi file (winxp -> no limit on avi size)
AUDIO:
audio compression: pcm, 44.1khz 16 bit stereo 172kb/sec
VIDEO:
video format: YUY2, 480x480
source: composite, NTSC_M
compression: no recompression
all other settings default
CAPTURE:
frame rate 29.97
lock video stream to audio
all other setting default
TMPGEnc: used to convert avi to S(VCD)
-PROJECT WIZARD
video type: non interlace
aspect ratio: 4:3 525 line ntsc
content of video: video movie
EXPERT SETTINGS:
VIDEO:
bitrate: constant
motion search: motion estimate
ADVANCED:
field order: top field first
AHEAD NERO: burning CD. -
Try changing this to "High Quality"Originally Posted by dmprice
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Since you are converting captured material, which tends to be noisy (esp when compared to DVD), I suggest that you use some noise filtering. There is noise that you cannot even see and it eats up bitrate. Either filter and frameserve from Vdub or use the internal TMPGEnc noise filter. TMPGEnc's filter will take some time but I hear it's worth it. 8)
A few details and you get all kinds of suggestions!"Art is making something out of nothing and selling it." - Frank Zappa
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
movie to mpg for dvd by toast too large; "keep in" been ignored
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 14:26 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
