guys i`m trying to squash an avi file down to the smallest usable playable size i can on a pda
i need some help though , i have been messin with all sorts of settings but cant seem to get the file small enough
full screen size on the pda is 280x180 although smaller may be usable as the software on the pda depending on player type may expand the file
i`m also using divx mpeg4 witha 4 sec key frame and 190 data rate , audio on a pda is not good so i`m using 20 kb 16 htz mono
can anyone give advice on shrinking down the file anymore , perhaps using the wmv format
i`m not experienced with codecs and compression but i`m sure there must be one that will give max compression with a small trade of for quality
the original file is about a gig with 21 chapters , 720x480 25 frames
i have got it down to 180 meg and the output is great on the pda but i need to get it to around 120 meg inc audio
pointers please guys
Decimate the frame rate to 15 FPS.Originally Posted by gilbates
doing that m8 gives me a jumpy playback
i`m looking to get just under a meg per min , at 296 x 216 in either divx or wmv formats , audio is mono but too low gives a sibalance sound on playback
whats the formula or software to do this guys
realy i want to do it straight from a dvd , without copying it down on to a hard disk , realy just to save time
resolution (?) image squashing problem with DVD rip
By suburban100 in forum Authoring (DVD)Replies: 9Last Post: 13th Sep 2011, 20:24 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 04:41 -
10 min max file for YouTube
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2010, 08:59 -
SUPER is squashing my 16:9
By sexiesadie909 in forum Video ConversionReplies: 2Last Post: 21st Jul 2009, 11:32
