Hello All,
I've just converted an Xvid to DVD using TMPGEnc 2.5 plus and the video is a little jerky. The quality/pixelation is fine and there are no blocky pictures just a little jerky. Its like the frame rate is not constant or something? but all the settings were correct in TMPGEnc as I have used the wizard and converted previous files fine?
The correct Codec was installed for the file........any ideas anyone?
hey, u probably got the field order backwards, go back to the wizard and where u see the field order change it from what u had it on last time, that might fix ur problem
hope this helps, josh -
Picture will get jerky also if you encode pal to ntsc or ntsc to pal and 23.976 to 29.97 without proper conversion.
Try this link:
https://www.videohelp.com/forum/viewtopic.php?t=205248&highlight=
Hopefully you will get better results. -
Ok I converted the xvid to mpeg...the original was in widescreen and very clear..but when I encodeded it, it changed to reg screen size an little distorted..How can I correct this..
Razz -
Experiment with widescreen output settings (use 16x9) in the encoder (whatever you use). Covert short clips (1 min) and check the results. It will take 10 min. to go through all output modes. Then pick the right one.
Image jerky after converting a DVD to MKV
By siocnarf in forum Video ConversionReplies: 2Last Post: 22nd Apr 2012, 14:14 -
jerky video playback in dvd player
By resloan in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2009, 15:09 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
Closed Captioning and jerky PC-based DVD video playback
By hollowman in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 09:17 -
RMVB to DVD, my umpteenth attempt, jerky video
By silverwolf0 in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2007, 04:32
