I turned on my PC...and it opend IE without me doing anything and went straight to some porn site. Anyway, I turned it off...and as soon as I did that, any other app I tried starting, it just wouldnt...it just stays there and does nothing. I don't know whats happening. When I restart in safe mode, I am fine, thats how I can post right now, and use any app...but if I restart again in normal mode, I can't open any app, or folder, it just stays there as if I didn't do anything. Anyway, does anybody have a clue why this is happening!?
Smile
Smile -
try a virus scan in safe mode, and go to msconfig and see wat's starting up.
Yep, it is certianly a virus of some kind of really nasty spyware.
If you have a virus checker, run a scan in safe mode like mujahid7ia said. Hopefully that will work.
If it does not, or you don't have an anti-virus program, what I suggest is to boot into normal mode and write down the URL and name of the porn site. Then reboot into safe mode. Go to a major anti-virus company like symantec or Mcafee and search their virus database for that porn site. In all liklyhood they will know the specific virus and how to remove it manually.
And if you have to do that because you don't have an anti-virus program, then you need to either download one immediatly or get out of your chair and drive to a computer store now to buy one.
My scanner has saved me from 3 viruses so far.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
I recommend the free AVG from http://www.grisoft.comOriginally Posted by Solarjetman
Not a RAM hog, IMO just as good as NAV or McAfee. -
Best solution.
STOP LOOKING AT PORN
Just run a spyware scanner like "AD-AWARE" :P
That will fix it. -
Well, stop looking at porn is not an option...who could ever STOP when it's right at your finger tips. Anyway, I used an online scanner and I had 21 viruses on my PC. Went out an bought myself Norton anti-virus. Hope that'll keep me safe. In the end though...I formatted my hardrive and started from scratch. Havent done that for a while..but thanks for the help everyone
Smile
Smile -
damn, 21 viruses! you must have been to a lot of porn sites to be that infected! lol. well glad you got it fixed. just be sure that norton runs at startup so it will always auto-protect.
Can you explain this noise in XP ?
By Seeker47 in forum ComputerReplies: 20Last Post: 9th Oct 2010, 06:24 -
Explain a child domain?
By capman21 in forum ComputerReplies: 1Last Post: 1st Oct 2008, 00:41 -
Can somebody explain the problem with this dv footage.
By Aarzoo in forum RestorationReplies: 8Last Post: 18th Jul 2008, 10:28 -
please explain different versions of Flashget
By jimdagys in forum Video Streaming DownloadingReplies: 2Last Post: 30th Mar 2008, 19:32 -
can someone explain?
By icucmerc in forum Video ConversionReplies: 2Last Post: 4th Aug 2007, 11:57
