Okay I need an expert or at least someone who understands more than me - should not be hard.
I have been trying to put some DV fottage I have taken onto DVD - I achieved this but the quality was poor.
I used Windows Movie Maker to download the video from the camera - I chose DV-AVI - if I understand correctly no conversion has taken place so nothing should have gone wrong here, and the video looks fine.
The video I am trying to burn is 1 hour 53
My first sucessful conversion to DVD was performed with NeroVision Express - trial version. Used NeroVison to open the raw avi and convert to DVD. However the quality is not good - you notice the difference between the camera connected to the TV and the DVD imediatly without out even looking hard. I could see no way to improve the quality. In Nero I set the encoding mode to High Quality (2 Pass VBR).
When I set the Quality setting nto High Quality rather than automatic it would not fit on a single DVD.
I then tried Sonic I get the message:
The Project will not fit on the media. Please reduce the project size. _ Agian this is a trial version with no help only a tutorial - could not find any reference to the error on the Web or their Web site.
I then tried TMPGenc and TMPGEnc DVD Author
My first attempt I used TMPGEnc to produce the .m2v and .wav file - I used the Wizard and left most of the settings alone - Set 2 pass Vbr and that is pretty much it.
The result burnt onto DVD again with the TMPGEnc DVD Author was worse than the Nero versio!?!
I then found a link on this site to http://dvd-hq.info/compression.html
I tried some of the suggestions there and encoded only the video however
TMPGEnc DVD Author does not like the .m2v created by TMPGEnc !?! and it took 40+ hours.
I get this message:
The video sequence header is incorrect.
If you are still reading thank you.
If you can point me at some help thank you even more!
All I want to do is convert my camcorder footage to DVD so the family can watch it - however I do need decent quality - I don't care if it take 40 hour as long as the results are good. (I have a decent PC - the nero conversion took 4 hours)
I am looking to test out the software to prove it does the job and then buy - oh I do have a limit of about £100 (UK) / $150 (US)
Thanks yet again
Shaun
Hi there !
Here are what I use and I spent about $ 150 total for my software:
Ulead VideoStudio 7 to capture tape to PC , edit , author etc
If VIDEO_TS folder is too big , I use Nero or DVDshrink ( free ) to transcode it
To preview it , I use imgclassic ( free ) to create iso to be mounted by deamon tool ( free ) and watch it on my PC
If I like the result , I then use Nero or DVDdecrypter ( free ) to actually burn it
If you want fancy DVD menu , you can also trial DVDLAB
VideoStudio , Nero do have trial out and they are quite good for my home use
Good luck, -
In TmpGenc, in the settings dialog, GOP structur Tab, you must have 'output interval of sequence header' set to 1 for DVD.Originally Posted by ShaunBrewer
When using TmpGenc for DVD, the simplest way is to use one of the DVD templates (PAL or NTSC) and then adjust the settings on the Video and Audio tabs to suit. Do not touch any other settings unless you REALLY know what you are doing as you risk breaking the DVD specs.
1h 53mins is quite a long video for DVDr esp if using PCM audio as you appear to be doing. I suggest you investigate mp2 or Ac3 audio as these are compressed and leave more room for the video than using uncompressed PCM.
To determine the correct bitrate to encode at you need to use a bitrate calculator such as the one here .
ADS DVD Xpress CapWiz Woes
By yaddablah in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2010, 12:13 -
Avi video from pc to camcorder
By billandjen in forum Video Streaming DownloadingReplies: 3Last Post: 14th Jul 2010, 02:51 -
Camcorder H.264 MP4 to AVI?
By biking_brian in forum Video ConversionReplies: 2Last Post: 4th Jul 2009, 18:48 -
DirectShow AVI Muxer + Infinite Pin Tee Woes
By JCipriani in forum ProgrammingReplies: 7Last Post: 5th Nov 2008, 18:52 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
