I have a DVI video output on my video card and DVI inputs in my TV and Monitor. I want to get a Y Splitter so I can view my computer on both. I am getting tired of plugging and unplugging. I found a Y cable, but it's $49.00. It may be my only solution, but I wanted to make sure it was going to work ok. Anyone know anything about this?
dj matty b
it should work - except the pc will not reconize the attached monitor correctly .. some cards are designed from the start to do this (matrox) , i dont know about others (maybe the same thing) ..
DVI-D that is (which is what the picture shows (accually DVI-I) , DVI analog only may have more of a problem -- but i know people who split the analog signal (DVI or D-sub Mini 15) to two monitors with out a correct distro. amp ... not really a good idea ."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
PC to TV DVI to HDMI signal issues
By GokuuSon in forum Media Center PC / MediaCentersReplies: 12Last Post: 12th Jan 2010, 12:34 -
Disapperaing analog cable channel on a split signal?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2008, 10:42 -
HTPC, DVI to HDMI, no signal
By ToYo in forum Media Center PC / MediaCentersReplies: 19Last Post: 8th Feb 2008, 07:10 -
DVI-D cable in DVI-I slot-possible? Quality loss?
By bigshotceo in forum DVB / IPTVReplies: 1Last Post: 21st Dec 2007, 07:49
