I running the latest verion of bbMPEG on an XP machine, and having a problem Mux'ing SVCD files that were encoded in the latest version of TMPG.
When I go to Mux the files together bbMPEG gives me an error message about opening an input file. It gets through the scanning of the video and audio streams fine, but when it gets to the point to begin Mux things suddenly stop and I get an error message "Error reading from input file."
What's odd is that this problem doesn't happen if I uncheck the "Add SVCD Scan Offsets" option under the Program Stream Settings tab. In that case, bbMPEG will mux the files together with no problems, but if I attempt to add those offsets, it craps out.
I've tried using the XP patch, but I still get the error message.
I searched the boards and found a couple old similar cases, but none were helpful and I was wondering if anyone else here ever had the same problem. I'm at a lost as to what to do. Could it be the TMPG files themselves? Are there codec issues I'm missing with bbMPEG and the mux'ing? (I did have issues a while back with Ulead software screwing up DirectShow and MPEG2's in TMPG and Procoder) Is this an XP issue? Could it be a system setting problem?
Any thoughts or help would be greatly appriciated.
