Just got a E80 and have a question about editing programs. If you want to cut off the first minutes of a program how do you enter the START of the edit. It seems you would have to keep a few seconds because the programs starts playing immediately before you could hit enter. Likewise to cut off the end of a program, entering the END of an edit. I usually set timer for a few minutes before and after a program airs and want to chop off the excess at the beginning and end before dubbing to dvd-r. Thanks.
I think I have an answer to my own question. Just divide the excess off as seperate programs. Right?
First press the direct navigator botton (NW of the enter button). Select the program you wish to edit with the up/down buttons, then press the right arrow button and select "shorten segment" from the menu. The shorten segment screen will appear. Select the start of the show with the transport keys, and select "start", select the end of the section you want to erase with the transport keys and press "end" then select "erase" and "OK"
When you go into the "Shorten Segment" mode, and it begins playing immediatly, hit the rewind and will go back to the very first second and then automatically pause right at the start. Then cut normally. It work the same for the end of a recording. You could use the divide feature, but you can also hit "Start" on the point you want to cut off, fast forward all the way to the end, and it will pause automatically at the end for you to chop off.Originally Posted by rw2516
When I had E80, I used fast forward or reverse to to the beginning or end. If you let it go, it will go automaticaly to the exact end or the beggining.
EDIT: Tonitrus, you beat me
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I've used the short segment to delete commercials from programs. It seems you would have to be quick on the trigger to hit start at the 0:00 point of the program. Since I'm going to be deleting the VERY beginning and end of a program(ex: "the following program is rated PG, etc), instead of doing: start-end-next-erase within shorten segment, just go into divide, fast forward to start of movie, and divide off what I don't want, erase that program, and dub the movie program to dvd-r.
Np you don't. Just follow what Tonitrus or me sugested.Originally Posted by rw2516
I understand what you guys are saying, now. I didn't read your posts very carefully. Sorry, and Thanks!
Question About on the Fly Editing
By guarddog in forum EditingReplies: 1Last Post: 29th Jan 2010, 03:07 -
editing question
By Noobmeister in forum Newbie / General discussionsReplies: 12Last Post: 1st May 2008, 18:19 -
Question about editing TV recordings
By gastrof in forum Authoring (DVD)Replies: 4Last Post: 9th Feb 2008, 11:51 -
Question on editing vc-1 file
By ultraman36 in forum EditingReplies: 2Last Post: 13th Dec 2007, 07:34 -
Panasonic E80 hard drive crash
By csanders1962 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 25th May 2007, 17:57
